RKB: the Swiss Premium-Class Bearing Manufacturer
Why to work with us
RKB bearings are widely used in this type of application. One of the most appreciated characteristics is the reliability of our bearings, that permitted many customers to benefit of a sensible reduction of unexpected equipment failure. In fact, the first quality bearing steel used, the optimized internal bearing geometry, the optimal rolling elements and raceways curvature, microgeometry and much more, lead to an excellent distribution of the external loads inside the bearing.
All these technologies, corroborated by the constant presence of RKB on- field technical personnel, are maximizing the overall bearing service life, leading to an increased reliability of the cereals rolling mill.
Application description
Rolling mill stands are used to mill cereals. The cereals are rolled by passing among two counter-rotating cylinders which are supported by two shafts. According to the machine type, there are also cylinders that can be heated during the milling process by means of the heat brought by a fluid. The shafts are usually supported with spherical roller bearings that can be conceived with cylindrical or with tapered bore depending on the machine type or by the desired bearing residual internal clearance after mounting.
The cylinders distance is usually adjusted by the user in accordance with the roller product or with the desired production rate.
RKB Bearing Technical Fiche
You can download the .pdf version of this article or visit the website for more details.
