New online Product Selector tool simplifies selection and ordering
Vadnais Heights, MN – Nexen Group, Inc. introduces complete Geared Bearing solutions based on their innovative Roller Pinion System (RPS). The new Geared Bearing package comes complete with a zero backlash gear mounted and dialed in on a precision grade high capacity bearing. Nexen’s Geared Bearings are available in a wide variety of sizes and gear ratios, and preconfigured for fit, form and function, for easy integration into any precision rotary motion application.
Nexen’s new Geared Bearing Product Selector tool makes it quick and easy to select the gear needed. Customers simply adjust online sliders for torque, gear O.D. size, accuracy and gear ratio requirements. The tool instantly shows all the options that fit. OEMs also have easy access to STEP files and specifications. Nexen holds bearings in inventory and gear raw material on hand, so bearings are available for fast delivery.
Nexen Geared Bearings offer unmatched mechanical system capabilities, including:
- High Indexing Precision: As low as ± 30 ArcSec with repeatability as low as ± 5.0 ArcSec
- Zero Backlash: Based on Nexen’s RPS technology, the Geared Bearing offers a rigid, zero backlash system
- High Output Load Capacity: Supported by precision grade, high load capacity cross-roller bearing
- High Speed: Handles speeds up to 632 RPM
About Nexen Group, Inc.
Our heritage is built on producing technically superior products while providing the highest level of customer support. As a leading manufacturer of precision motion control components, power transmission and web tension control products, Nexen works to remain at the forefront of cutting edge engineering and production excellence. Our production capabilities include computerized control and testing systems, dry cutting applications, special coating processes, over 80 multi-axis precision CNC machine tools and automated assembly. By working with Nexen, our customers experience innovations that adhere to industry specifications, optimize their metrics and provide solutions focused on increased uptime, longer machine life and reduced maintenance.
Julie Eleftheriou
Tel: 952.913.3065
